Home > Maintenance & Mods (L322) > tail light on
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
tail light on
Something that I noticed after I had washed my beast.
The top half of left hand tail light was on.
Checked that I hadn't turned on lights...nope.
Had all doors and tailgate open to drain water..
Closed all doors, tail light still on.
Put beast back under carport and no tail light on.
Is this something that RRs do as I've never had it happen before.(Had the car 2 years)
The lights were replaced with new ones October last year after I was rear ended.
Thanks
Post #378602 21st Mar 2016 4:46am
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi
Are you sure you didnt turn on the "park light" by mistake?
Engine off and indicator stork left in the right turn/left turn position will turn on the side lights of the corresponding position.
Just a thought.
Cheers, Jerry
Post #378608 21st Mar 2016 7:34am
If its the top half? That would mean the brake lamp... Parking light should only illuminate the bottom half Thumbs Up
Hopefully the OP has made a mistake and it was as simple as a parking light Whistle If not, i would suspect a water leak (when washing) into the OSF behind the bonnet pull, as thats where the LCM is situated... Pull it out and check for any current or historic water ingress symptoms sir Thumbs Up
Post #378618 21st Mar 2016 9:44am
as the tail light has two bulbs in the lower part i wonder if the OP means the top one of the two .. ... - .- -.
Post #378624 21st Mar 2016 10:00am
littlecub
It was the TOP half and yes I had the indicator pointing down.
But its not on anymore as I've put it to bed for the night. Laughing
Post #378631 21st Mar 2016 10:55am
