Home > Technical (L322) > TDV8 intake manifold tuning valve location
proser
Hi,
Can someone please help me to locate the IMTV.
FF gone into limp mode and fault code - P0661-11 (2F) Intake manifold tuning valve control - circuit low - bank 1 - general electrical failure - circuit short to ground. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #372922 18th Feb 2016 11:00am
proser
the only pic I can find is in the Workshop Manual
But it does not say where it is located. Evil or Very Mad Regards
Mark
2012 Westminster
Post #372950 18th Feb 2016 1:30pm
proser
After a lot of investigation I have found the location. It sits on the underside of the intake manifold between the throttle bodies.
Now need to speak to dealers tomorrow to see if they can locate the part on the system, but I have a feeling that it's going to be a complete manifold
 Regards
Mark
2012 Westminster
Post #373023 18th Feb 2016 10:01pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi
How did you get on?
Cheers, Jerry
Post #378315 19th Mar 2016 9:57am
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Two screws to remove it, problem is you need to remove the manifold. I'd check also the vacuum line to it which is accessible from the top.
Post #378316 19th Mar 2016 10:09am
GraemeS
Isn't that just a vacuum chamber? The fault code description refers to an electrical short to ground in the control circuit.
Post #378323 19th Mar 2016 11:50am
proser
The WSM gave a picture of what is circled as the valve, but after a lot of investigation the IMTV is actually the electrics of the EGR.
The fault codes were due to a short in the wiring for the MAFs Regards
Mark
2012 Westminster
Post #378333 19th Mar 2016 1:59pm
