Home > Technical (L322) > Tow bars
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Tow bars
Does anyone know if an OE LR towbar from a 2003 4.4 V8 petrol is a plug and play fit on a 2006 TdV8? I don't know when the connections changed to 13 pin (it is 13 isn't it?). Cheers.
Post #377557 15th Mar 2016 2:47pm
Pilgrimmick
Scotland 2004 Range Rover Vogue Td6 Java Black
Not asking about the tow bar, but the electrical connectors instead?
I believe that the later 13 pin can be retrofitted quite easily, but will have some redundant pins. Got enemies? Good, you have stood up for something in your life.
Never regret growing old, it is a privilege denied to many.
Post #377628 15th Mar 2016 8:52pm
rvbush
Thanks, but what I really want to know is whether the towbar and associated electrickery is compatible. In other words can you take everything off of the 2003 car and fit it directly to a 2006 TdV8? Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #377650 15th Mar 2016 10:26pm
holidaychicken
Re: Tow bars
I believe it's a different system on the later models but you could check on the PF Jones website as it allows you to choose tow bars and wiring kits for different models and years of manufacture. Westfalia is the OEM kit I believe
Post #377651 15th Mar 2016 10:28pm
rvbush
Ah, thanks. I'll do that tomorrow when I'm more awake! Thanks again. Drives:
Post #377654 15th Mar 2016 10:36pm
Yes you can ish!
The metal bits are the same exept for the exhaust hangers on the later cars... Easy to overcome though Thumbs Up
Wiring is the same unto 2009my> then its just another kit type Thumbs Up All plug & play though Thumbs Up
Post #377677 16th Mar 2016 1:01am
rvbush
Very helpful guys, much appreciated. Drives:
Post #377687 16th Mar 2016 6:53am
