Home > Technical (L322) > no radio! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
first thing i would do is dis-connect the battery for a while, this sometimes helps...have you done a search here for an answer..
22nd Nov 2010 9:32am |
Have you checked for moisture in the ICE compartment? Next step is to unplug the big multiplugs from the various components in the boot and give a liberal squirt of Electrical Contact Cleaner. I personally wouldnt use WD40 on these components, but have heard others have. In the future, always run the car with the AC on to dry out the interior air. |
22nd Nov 2010 9:46am |
Happened to me on a stock S-Type "R" 4.2 Supercharged Jag and all it needed was to be turned off an on again. I suggest you disconnect the battery and reconnect.
22nd Nov 2010 9:58am |
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 |
thanks for the replies- i will have a play around in the boot tonight and report back my findings. |
22nd Nov 2010 10:46am |
had a good play with the radio over the weekend/last night. found the fault to lie with the bm54 unit, removed the unit and tried a replacement out of a firends car and the system worked perfectly!
30th Nov 2010 9:39am |
