Home > Maintenance & Mods (L322) > Severe juddering through steering colum |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2634 |
Sounds very much like a caliper issue, had the exact same on my old car, was undriveable until fixed. Take it for a run, doesn't need to be far, get out & put your hand on the road wheels in turn. The one that's hot is the one with a sticky caliper, not an expensive fix, available from Dan @ Duckworths. |
15th Mar 2016 11:52am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
I had such vibration with a rear calliper sticking. Go for a run then squirt water on each of the brake discs. The one that steams is the faulty one. |
15th Mar 2016 12:27pm |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
could be wheel balance. |
15th Mar 2016 12:28pm |
Diver Bryn Member Since: 16 Jan 2012 Location: Durham Posts: 34 |
Thanks Chaps.
15th Mar 2016 12:47pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
I had exactly the same experience with my classic RR, at about 50mph the front of the car shuddered and the steering wheel vibrated. I investigated as you have done, and discovered the following:-
15th Mar 2016 1:34pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
ive seen plenty of posts regarding sticking calipers, but not after a pothole. i sometimes see other cars with wobbling wheels. you would think that its the the wheel . but sometimes people buckle tha actual hub itself. this is normally removable and holds the wheel bearing(s) they are changed as a whole when said bearings fail you can pick these up secondhand, on ebay. as you only buying to disproove etc. if you are sure its not the wheel, as you moved them about, it is possible its the hub.
15th Mar 2016 5:27pm |
Have you checked steering rack for play and movement? |
15th Mar 2016 5:37pm |
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 |
Hi, I have what sounds like exactly the same symptoms on my L322.
3rd Apr 2016 1:09pm |
Update: jacked all four wheels up and nearside front definitely binding so I will try replacing the caliper. Not sure how that can explain such severe vibration though...?
3rd Apr 2016 2:28pm |
Think it's something to do wth the vehicle weight, they're heavy old buses! |
3rd Apr 2016 3:39pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1372 |
I had this with my 2004 4.4. I put the juddering down to the interplay between one front wheel rolling free and the other braking due to the seized caliper. Only Range Rovers since 1988 |
3rd Apr 2016 3:57pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 534 |
I had a seized o/s front calliper recently, same symptoms, severe steering judder. Very nasty smell, oh and lots of smoke (cooked pads). Drives:
4th Apr 2016 2:34pm |
Forgot about that , had mine on fire before |
4th Apr 2016 6:33pm |
Thanks everybody for the help
4th Apr 2016 10:24pm |
