Home > Technical (L322) > 2012 adaptive headlights |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Yep, bi-xenon meaning a dual beam xenon projector, but there are also additional halogen main beams.
14th Mar 2016 7:43pm |
Berty Member Since: 04 Jan 2016 Location: Leeds Posts: 73 |
So what would I need to improve my full beam, and make my fogs whiter?? And how involved is the fitting, will it cause any issues, I've heard a few aftermarket bulbs cause warning light to come on, also can I change the side light bulbs I like this look, thanks berty
14th Mar 2016 8:36pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6733 |
LEDs for fogs. Whiter than a white thing :-
14th Mar 2016 8:48pm |
Where did you buy them m8 ? thanks berty |
14th Mar 2016 8:55pm |
Sidelights are built in so not changeable. You'd need a pair of H7s for the main beam and H11s for the fogs (the Xtreme Whites would be what you're after). As high quality bulbs drawing standard wattage, they shouldn't cause any issues (fully legal also). Others will be able to advise better as regards fitting (I'm not a FF owner). LEDs as above wouldn't give a fog beam, though there are those available that do, at a cost. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
14th Mar 2016 9:03pm |
Right on investigation of my yellow main beam headlights it would seem there a halogen build so how is that a bi xenon headlight ? I always thought bi xenon meant xenon full and dipped, is this another money making spec change by Landrover or has my car had a bump at some point :unsure: |
15th Mar 2016 6:50pm |
See my PM - if they're adaptive, they are xenon, but they still have an additional halogen bulb. Visiting from DISCO3.CO.UK
15th Mar 2016 8:10pm |
