Home > Technical (L322) > "Fuel Air Metering" Fault |
Good to see you over here on the dark side!
21st Nov 2010 10:06pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
I think that's a generic O2 sensor code, I seem to remembermy old Maserati throwing that code up when the 2 pre-cat sensors were shot 2006 Mercedes CLS
21st Nov 2010 10:08pm |
And a quick google of the code...
21st Nov 2010 10:09pm |
motosport3 Member Since: 21 Nov 2010 Location: San Francisco Posts: 6 |
Thanks for all the feedback and info everyone.
21st Nov 2010 10:18pm |
The exhaust is definately worth a punt, isn't there a recall for it in the US? The only reason I'm dubious about it is that the same reason was given to the previous owner of my car by a LR dealer. Yet there is no crack, just leaky PCV hoses. There is also a guy on here who just bought a RR from a dealer with a "blown head gasket" again similar codes. Trouble is vacuum or exhaust leaks cannot actually be detected by the ECU so it tends to throw all sorts of other spurious codes. You posted a few pics on rr.net of your engtine cover off - but I didnt see whether you had checked the hoses? They are further back under the pollen filter housing (easy to remove) RE the code reader, search eBay for USB OBD you want something like this, but preferably more local unless you dont mind the wait. Dan |
21st Nov 2010 10:32pm |
Thanks for the prompt and informative responses Dan.
21st Nov 2010 10:52pm |
The bundled software is a good start for reading and clearing codes, if thats all you want to do then its OK. I use a dodgey version of digimoto which can be found on most torrent sites |
21st Nov 2010 11:03pm |
Cleared up and I've become more proficient already at removing the cover. Took off the air fliter this go around as well.
22nd Nov 2010 12:18am |
Interesting - your hoses have been replaced at some point. Originally they would have been fastened with BMW crimp clips, where as now yours uses jubilie clips.
22nd Nov 2010 8:20am |
I did just have my coolant expansion tank and expansion tank hose to thermostat replaced on Friday before the SES light came on.
22nd Nov 2010 9:02pm |
Brought car back to my local shop and had them pull the code again. This time
24th Nov 2010 5:15am |
