![]() | Home > Technical (L405) > Terrain Response or other? Problem, help! |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
I never had this at low temperatures... got get your car to the dealer - that is def. not ok. |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
That is not normal behaviour. To get that display, you should have the auto terrain function set to a manual setting and not be on a road setting. |
Have you looked in the manual to see if there is anything about such behaviour. I can imagine that if slippery the auto terrain response does something but don't understand that is it only at low speed, I mean I would expect it more at higher speed. Also I'd expect a warning about temperature/slipperiness even before the terrain response started to do something........... MY 2010 5.0 SC Galway green and sand interior!!
The auto-terrain will put the car in "Grass/Snow" mode once (I think) the cold weather warning light comes on (at +3C, I believe). There isn't any indication that it has done that, other than the car being sluggish (nothing on the info display).
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Doesn't sound right. Mine does not have reduced performance and we have had minus temperatures a lot recently. Try using the 4x4 info screen in the main display to see what decisions the auto terrain is making. 2019 D5 HSE Lux SDV6 Indus
