![]() | Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I've been running slotted / drilled discs for 25K, and have found them to be fantastic at stopping the lump |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8445 ![]() ![]() ![]() |
Yep, I think the technology is proven, just have to wait and see how good the quality of the casting is, IMHO that's the deciding factor in brake discs, if it's poor quality and the metal composition wasn't correct then they will not disperse heat evenly which will lead to warping....
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
hats off to you pete.
Cheers Greg...
Frank Elson Member Since: 20 Feb 2016 Location: Blackburn, Lancashire Posts: 34 ![]() ![]() ![]() |
Excellent read Pete. Took me two days, with a few breaks for meals and some writing of my own...
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
This has been an excellent read, you have done so much with the motor.
Thank you chaps, glad you enjoyed it... probably be at the LRO show in September, maybe others...
Front screen has had a small crack in a corner for a while now, been meaning to get it changed as the heating elements have had it as well... one line works out of the 600odd on there... anyway, out in some pretty horrible rain earlier and I noticed water running down the inside of the passenger "A" pillar...
She did ask if I knew if it was an acoustic screen... I haven't a clue... just want what it had in it from the factory...
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
Mine has a part number stamped in it they could pull the details from. Ed |
Thanks but yours will be different connectors to mine.... Pete
I wasn't suggesting that. More you could give them your number... |
Oh, right... I'll have a look tomorrow... Ta....
Might be different but mine's bottom passenger corner under the Pilkington logo. Ed |
