Home > Maintenance & Mods (L322) > right rear mudflap
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
right rear mudflap
My right hand rear mudflap has come loose from the body work up near the top just behind the wheel arch.
It looks as if its been glued into place.
What type of adhesive is used to put it back onto the body work.
I'll have to take it off and clean the old gunk off before I reattach it.
Pics attached.
Thanks
Post #376454 8th Mar 2016 11:04pm
proser
use something like tigerseal Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #376457 8th Mar 2016 11:30pm
They usually have a bolt through the top... Thumbs Up
Post #376462 9th Mar 2016 12:23am
miggit
If you have to glue it back then a polyurethane flexible adhesive (PU flex) is the best thing to use, it is the suff that the manufacturers use to stick most of the car together with now a days.
Your looking for something like this http://www.ebay.com.au/itm/Sikaflex-227-po...XQfRdR5io9
when you get covered in the stuff, and you will Shocked , acetone (nail polish remover) or White Spirits will be your best friend Wink
You'll need to hold the mudflap in place for about 24 hours to allow the glue to dry, unless you can find a friendly windscreen chap as their version drys in a few hours Thumbs Up
Oh and it comes in black, white and grey.... and it's over-paint-able when it's dry. Yesterday I couldn't spell Engineer... Today I are one!
Post #376540 9th Mar 2016 2:01pm
littlecub
Cam-Tech-Craig, Its got a bolt through the top, but its on the arch, this is just behind it on the body.
Miggit, Thanks, I'll have to see a friendly windscreen chap then as its used as the main transport.
cheers
Post #376624 9th Mar 2016 10:41pm
