Home > Technical (L322) > Diesel Induction cleaning..... HELP!
Page 2 of 3 <123>
miggit
^^Sweet Thumbs Up That's just what I needed to hear, cheers Buddy Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #369837 1st Feb 2016 12:19am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Thinking about this too.
Any update Miggit?
Post #375825 5th Mar 2016 10:34am
miggit
At this present moment in time it is nothing more than an idea, as the bloody gearbox has gone fubar again Evil or Very Mad Evil or Very Mad
This was the best deal that I could find on the stuff http://www.autosessive.com/products/60240/...tarter-kit
Post #375934 6th Mar 2016 6:59am
Clivefog
Having had Diesel engines for over 20 years, a good scrape and then soak and brushing with Diesel cleans most of the crud off. Intercooler can also get gunged up, again fill with Diesel overnight and flush out with water, not a pressure hose as it is a little fragile.
The gunge on Toyota came from blow by, through the crankcase ventilation system and back into the air intake pre turbo, so everything gets coated in Diesel and oil emulsion.
Terraclean will do whatever it does from injectors onwards not the air induction system.
As recommended take it off and clean it, and yes it does get messy. If you have a friendly garage with a parts cleaner maybe worth a few notes to save all the gunge getting over you.
Post #375949 6th Mar 2016 9:07am
PaulB
Yep I found that site too.
I presume we need two bottles, one for each intake hose?
Post #375977 6th Mar 2016 1:55pm
miggit
Err you will... Whistle but I only have one of everything as it a TD6 Mr. Green ..... but then you've twice as many horses under the bonnet Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #376001 6th Mar 2016 4:29pm
PaulB
Embarassed
Post #376017 6th Mar 2016 5:28pm
rar110
Initial treatment is two bottles. Then a half bottle for each intake as a maintenance treatment. ______________________________
Post #376040 6th Mar 2016 8:20pm
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Mikey wrote:
I'm talking about this being drawn into the combustion chamber...
This pic is also similar to my TDV8 intake and and after removing the intake and egrs to clean i have concluded but open to correction the following
This gooey crud is a result of egr gasses mixing with the intake. It it what you will find in the intake after the point the egr pipe enters the intake. The intake will be cleaner and not have this goo present in the intake before the egr. To prove this remove your Inter cooler hose, its still has a oily film but it is nothing like you will find post egr.
As can be seen my left intake clean prior to the egr, the can be seen on the left after the throttle, yes its that hard to make out thing. So being it is clean prior to throttle this would suggest the intercooler will also be cleaner than the intake as mentioned previously.
This pic is the right intake with the throttle removed, im sure that sensor if functioning was not operating correctly. The egr pipe can be seen clearly protruding into the intake and there you have the start of the mess.
Some goo can be seen also upstream, im guessing it may enter the intake with some pressure or its cased by back pressure or both.
Pic of end of intake.
Egr valve pipe very clean
Egr valve is cleaner than photo looks cleans up perfect in 2 minutes.
I'm guessing the rest of the exhaust would be similarly clean and turbos even better with the additional heat.
There is no way an additive will clean all the sludge out off the intake. Only manual cleaning will do that. The cleaning is easy just dirty.
But an additive would help clean out the looser layer and clean the the sensors. You can spray can after can of of throttle body cleaner into the manifold with it off trying to clean it and you will go broke in the process. I scraped mine, hi pressure water sprayed it, used cans of throttle body cleaner and stuffed rags through it several times to clean it the best i could and still some oil kept coming out.
The egrs gasses are the problem and if you can stop the cause that's a good start . There is no easy way to clean the rest of the intake so i think that's where a regular intake treatment will be helpfull and over time with the egrs out of the picture the rest of the intake would probably improve. But otherwise treatments will only band aid the situation.
I don't think the intake goo would have any impact on the turbos.
Post #376059 7th Mar 2016 12:12am
miggit
I hear what you are saying, but my TD6 had some of the dreaded goo coating the inside of the pipe that came from the intercooler, before the EGR....... as I got plastered in the bloody stuff when I removed my EGR valve Shocked
And it was way worse after the valve, as I found when I had the inlet manifold off to do the injectors, but the manifold splits 2 ways on the BMW engine (18 port head Evil or Very Mad ) and there is a lot of air ways contained in the head. So it would appear that to do the messy and sticky manual clean would involve the removal of the head, and there is no way that I'm going to do that Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #376087 7th Mar 2016 9:55am
Hammer
Hmmmm that does sound a little more complicated.
Paul
Post #376143 7th Mar 2016 12:51pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Old thread I know, but how did you get on miggit?
Post #514191 4th May 2019 9:29am
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
When I bought my tdv8 the documentation showed big bills for having both knackered egr valves replaced with new, car had 124500mls on it, I have religiously put in a full bottle of redex EVERY time I fill up, for the last year, whether I fill the tank or not, at around £3-4 a bottle I see it as, preventative maintenance,I'm terrified of me turbos curling up on me so I'm going to give the revive stuff a go too and prob strip down as much of the induction side for a clean out. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #514214 4th May 2019 12:52pm
telly-addict
Yeah I got I bottle of Revive before realising I needed 2...£70 ffs Evil or Very Mad Cam
2011 TDV8 Vogue in Stornoway Grey
Post #514227 4th May 2019 1:32pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I tool the inlet manifold off and cleaned it with oven cleaner then soaked it over night in a concentrate of degreaser and hot water over night, it came up spotless. After that I fitted am egr blanker so it will never get to that state again.
Post #514312 5th May 2019 1:48am
Page 2 of 3 <123>
