Home > Technical (L322) > Cold Climate things kind of not working
somchie
Sweden
So.
Heated windscreen front and rear and heated steering wheel works but it's soooo slow!
Ice on the windscreens will barely melt.
No battery issues or and warning messages, battery is a year old and the car us driven daily.
Any ideas what could be wrong? Range Rover SV Autobiography LWB 5.0 S/C -17
Aston Martin Rapide S -17
Range Rover Sport SDV6 Autobiography Dynamic -14
previous: Range Rover 5.0 Supercharged -10, Land Rover Defender 110 SW LXV -14, Discovery 4 HSE -11
Post #375936 6th Mar 2016 7:09am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
HI
Could you give us an idea of how cold is cold where you are..?
The heated screen do work well but are not intended to clear 1 ft of snow off the screen in a hurry. Excellent for a covering of frost or a small amount of ice but if the temp is so cold, any melting ice/snow could just re freeze.
I don't believe they have variable temp settings - either on or off so it may just be too cold to what you want. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #375938 6th Mar 2016 8:09am
somchie
Sweden
Hi!
Thanks for replying. Well. Even with just a bit of ice on the windscreen takes forever, it's enough with just a few degrees below zero. It takes for forever on the Fullfat compared to the RRS and even the Defender. Range Rover SV Autobiography LWB 5.0 S/C -17
Post #375967 6th Mar 2016 11:55am
Does it all work? If it starts to mist up and you push the button, does it all clear or just lines? If its just lines then its finished and needs replacing sir... Wifies Disco now only has 6 lines left working out of about 600 Shocked
Post #375985 6th Mar 2016 3:14pm
I have one solitary line left on mine, it is right in front of the driver so really helpful... Rolling Eyes must get it changed... Thumbs Up Pete
Post #375990 6th Mar 2016 3:25pm
