Home > Maintenance & Mods (L322) > 2010/12 Taillights Issues
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
So my mechanic tried to install 2012 LED taillights into my 2007 Vogue and after a brief moment of happiness when it turned out that a plug and play method gave no fast blinking turn indicator I noticed that my fog lights are on constantly. I also get disco effect when ignition is on.
Is there an easy fix for these issues or do I need to get the expensive wiring kit from supertweaks at GBP 225?
I have read that I can cut the fog wire and connect the wire from the car to a resistor and the other side to ground but then I have no fog lights and it may cause issues with MOT. Also disco lights when ignition is on will remain.
Any help will be appreciated.
Thanks! 07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #375854 5th Mar 2016 1:48pm
this is from the wiki and it looks like cliff used the same boxes as you 'might' have to buy.....i'm sure there are other magic boxes available...
http://www.fullfatrr.com/forum/topic9647.html ... - .- -.
Post #375858 5th Mar 2016 2:04pm
Sql
Yup, have seen that topic Stan, thanks.
I guess I will have to buy that if there is no other way around this. 07 3.6 TDV8 Vogue
Post #375860 5th Mar 2016 2:16pm
AzizRR
Bahrain
i bought these and received them week ago, gonna try them as soon as i receive my inserts .
http://www.ebay.co.uk/itm/161977916334
Post #375920 5th Mar 2016 10:05pm
Can i give you a free top tip... You have a tow bar yes? Cut the Yellow/Black wire to each rear light (fog light) connect this to the Blue wire coming from your trailer electrics (rear fog light feed)
This will stop your rear fog light issues by feeding the rear fog lights a clean on/off feed from the towing ECU sir...
Then simply have the CCF files altered to turn off the hot & cold monitoring on the rear lights Thumbs Up
NO need to use nasty boxes then sir Whistle
Post #375922 5th Mar 2016 10:16pm
AzizRR
Bahrain
Headlights wiring tip please? just to complete the day Very Happy Very Happy
Post #375923 5th Mar 2016 10:20pm
Sql
Craig, that's what I was hoping to hear! Thanks a lot sir!
How do I alter the hot and cold monitoring, do I need IID tool? Can diagnostic software used by independent LR services do that? 07 3.6 TDV8 Vogue
Post #375968 6th Mar 2016 12:01pm
Yes & yes??? IID will, some indy diagnostic kit will, some wont sir... Thumbs Up
Post #375982 6th Mar 2016 2:58pm
AzizRR
Bahrain
Tried the boxes, works perfect!
Post #376889 11th Mar 2016 4:26pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
mine do the disco for a few seconds upon start up and the half lit fog....but neither of these bothered me enough to do anything about it and I'm really OCD about my cars/toys 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #376920 11th Mar 2016 6:51pm
Sql
So I finally got round to fitting the taillights.
New questions.
@Cam-Tech-Craig, you explained that I needed to connect the fog light wires to blue wire from tow bar electrics - it turned out there were two blue wires in there, if I remember right one was blue with red strip and the other one was blue with some other color. Which one should be our connection winner? Didn't want to try and connect it to an incorrect blue one so ended up with fog light wires just cut and with a nice "Check foglight bulb" greeting on the dash Smile
Please let me know your thoughts if possible!
Side note - wow these LED taillights are bright! I wonder if they should be that bright or they get too much power now?? 07 3.6 TDV8 Vogue
Post #381397 9th Apr 2016 9:56am
Check first with a circuit tester sir Thumbs Up
Post #381403 9th Apr 2016 10:41am
Sql
Thanks Craig. I hope my mechanic will know what to look for with the circuit tester.
One more thing - should these taillights be so bright? Especially turn signals, damn they are blinding!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  07 3.6 TDV8 Vogue
Post #381511 9th Apr 2016 8:24pm
betonklinker
Netherlands 2004 Range Rover Vogue Td6 Bonatti Grey
Dammm beautiful rear lights, did you 've sold the old lights? I use Google translate, Sorry for my bad English...
Full Vogue Td6, new Gearbox, 22 inch Stormers, HSE, Cream leather
Post #381523 9th Apr 2016 9:57pm
miggit
You can turn off the bulb monitoring with NavCoder, if you can't afford IID Tool.....
http://www.navcoder.com/
And you will need a lead like this http://www.ebay.co.uk/itm/For-BMW-USB-OBD-...SwFqJWnhu0 Yesterday I couldn't spell Engineer... Today I are one!
Post #381530 9th Apr 2016 10:18pm
