![]() | Home > Technical (L322) > Main dealer engine oil change |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35643 ![]() ![]() |
ah, didnt know that... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
My local Indy offered an oil change with filer and an oil flush for £150 (TD6) so unless the TDV8 has a sump 3 times the size of the BMW lump, I would say that they is extracting the urine |
I think its funny the way some people perceive that Land Rover do some magic when doing a Service 1/2 etc.
I guess it all depends on the staff at the local KF.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I'd agree with you Gary, same garage but must have been different staff as I've had mixed results from them. FF was fine 110 wasn't, both within 6 months of each other.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
just got in touch with local kwik fit to ask on price for oil change £65 -not bad
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
On TD two drains I wonder if they know
surely if they drain from the rear plug ,all oil is removed and no need to remove front 1 ?
Agree but they put Two in for a good reason so best not ignore that fact. Many thanks
wont use them anyway ,as I only use Castrol or mobil oil ,and want a genuine filter |
So total waste of time calling them and posting on here then. Many thanks
no not a waste,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2648 ![]() ![]() |
The rear plug drains a small reservoir - there is a wall between the 2 sections so oil will not be drained fully if either plug is not removed. |
