Home > Technical (L322) > No Faults??
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
No Faults??
I just got my GAP tool... Thanks Dan! Did the update etc read the faults, cleared the faults then read them again. No Faults! Is that possible?
Post #375478 3rd Mar 2016 11:25am
Lost for Words
You don't mention a drive cycle inbetween...? Question Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #375480 3rd Mar 2016 11:32am
Mcnallykev
Rolling with laughter Rolling with laughter Rolling with laughter That'll be it then! Expect a lot of these posts!
Post #375481 3rd Mar 2016 11:33am
Mcnallykev
only 1 Fault after that. Lost contact with the PCM
Post #375493 3rd Mar 2016 12:07pm
i'd leave it for a week or so , that way you'll get a more comprehensive check.. ... - .- -.
Post #375499 3rd Mar 2016 12:13pm
Mcnallykev
The excitement! No work done this morning. Although scared to do some things. Like do I select 13 for my tow bar electrics? It doesn't say 13 pin it just says module 13.. Is it a 16 way seat I have? Do I need to tell it what kind of speakers i have!
It doesn't bear thinking about!
Post #375501 3rd Mar 2016 12:17pm
Lost for Words
Leave the CCF alone unless specifically necessary. It's an area that needs caution and sufficient voltage while flashing is essential to prevent failure. By all means play with the live values etc. but the CCF and ECU flashing is not to be used lightheartedly. Thumbs Up Visiting from DISCO3.CO.UK
Post #375507 3rd Mar 2016 12:28pm
Mcnallykev
Oh, I was straight in no kissing! Changed DRL's, Alarm Chirrup and towing things. Looks like I was lucky!
Post #375509 3rd Mar 2016 12:31pm
top tip, whilst you are playing with the tool make sure the engine is running or you have a battery charger attached other wise you'll soon get a flat battery... ... - .- -.
Post #375514 3rd Mar 2016 12:37pm
Mcnallykev
Post #375516 3rd Mar 2016 12:40pm
Lost for Words
The CCF flash is only quick, so it's not normally a problem unless the battery is a little worse for wear. Changing parameters that outn't be changed is still a risk too, of course, but GAP don't include access to problem ones.
The IID is very reliable for flashing and recovery, but prevention is better than a cure. Thumbs Up Visiting from DISCO3.CO.UK
Post #375517 3rd Mar 2016 12:40pm
Lost for Words
To expand on Stan's comment, for functions like CCF editing and ECU flashing, of course, you can't have the engine running, which is where back-up power comes in. It's important to note that a standard charger is NOT suitable for flashing ECUs, due to the excessive voltage ripple and hence a smooth supply mode is required. Thumbs Up Visiting from DISCO3.CO.UK
Post #375519 3rd Mar 2016 12:44pm
Mcnallykev
I'm getting scared now! I edited the CCF with the engine running. It the turned it off and did all the stuff. The only caveat was when the upload was complete to start stop and start the engine again. Seems to be fine now and my changes have certainly been applied.
Well, the ones I can check quickly like alarm and DRL.
Post #375521 3rd Mar 2016 12:52pm
its ok, i adjust my ccf with the engine running..i think flashing ecu's needs the engine off and battery charger attached.. ... - .- -.
Post #375524 3rd Mar 2016 12:57pm
Lost for Words
It's only the writing that is the important bit (well, and reading). As far as the running engine goes, until you select upload it hasn't done anything to the car. Thumbs Up Visiting from DISCO3.CO.UK
Post #375525 3rd Mar 2016 12:57pm
