Home > Technical (L322) > 3.6TDV8 Brake Caliper Confusion...
jonnyboy54321
This is most interesting - I was under the impression that my brembos were an upgrade. Evidently not.
So when it needs pads - what do we recommend? Upgraded aftermarkets or standard fit?
Same for discs - what gives it more "stop" ?
TIA 2007 Vogue TDV8 with 255/55/20's fitted
Post #374377 26th Feb 2016 7:06pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Perhaps those afflicted with the same "disease" as mine should look for a group buy to all upgrade Rolling with laughter Ash
2016 SDV8 AB
Post #374387 26th Feb 2016 7:40pm
I think to some extent it is in our heads.
I have 2 pot calipers on the front of the disco, never I have I thought OMG I'm not going to stop, even when I've had to stand on the anchors!! Yes the brembos are better, but Are we really saying that LR fitted cars with "inadequate" brakes? Bigger discs, pads and calipers will obviously stop a car faster, but what do we think the actual difference would be?
It would be interesting to know!
For this I thinks we would need a runway, some flags and a tape measure Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #374398 26th Feb 2016 8:17pm
comports
Rolling with laughter Thumbs Up Ash
2016 SDV8 AB
Post #374410 26th Feb 2016 9:00pm
Gents, to further my earlier post. If you have an 09my 3.6 with 2pot brakes you cannot use the older type 4pot Brembo’s as an upgrade as the bolt holes in the castings will be way too large without using some form of spacer/reducer...
The bolts that hold the calliper holders (2pot) or the 6pot Brembo callipers are something like 12 or maybe 14mm whereas the older MY 4pot Brembo’s use 6 or 8mm bolts...
Post #374455 27th Feb 2016 12:00am
