Home > Maintenance & Mods (L322) > Small diesel leak TD6
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Over the last couple of days I have been getting a slight diesel smell around and in the car. Had a look for the obvious around the high pressure pump , filter pipework etc and nothing obvious. Took the centre cover of the engine and again nothing obvious. Next plan is to take off all the engine covers and possibly inlet manifold to have a look at the top as I have just noticed a tiny drip on the floor towards the the back of the engine.
Is there anything known I can have a look at. Are there any o rings or seals on the top that are known to fail.
Car is running great. I have searched online but only the high pressure pump at the front comes up. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #374239 26th Feb 2016 3:49am
bizzybus
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
fuel leak
has the car got a pre heater, i had an overflow on mine a couple of times I know you wont be using it down there but worth a look Wink (SEE WHAT HAPPENS WITH HEATED SEATS)
Post #374354 26th Feb 2016 6:13pm
Weegie
Possible?
http://www.fullfatrr.com/forum/post373175.html#373175 John
GAP iiD BT
Post #374363 26th Feb 2016 6:43pm
wayneg
Had a good look today with the engine covers and the hevac plenum off. The only signs of wetness is on the top of one injector. A quick google shows it could be an O ring on the diesel bleed off return. There is no pooling of fuel but I suppose it will readily find a path down. Now to find a suitable O ring. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #374829 29th Feb 2016 9:09am
wayneg
Well its taken me long enough but at last I have found my leak. The low pressure fuel hose where it connects to the top of the high pressure fuel pump was oozing fuel very slowly. One of those places you can see but just about get your fingers to. Anyway the jubilee clip had a knackered head and was not done up tightly presumably by whoever ruined it. Hose removed from pump, 3/4 inch trim off the end and back on with a new Jubilee clip nicely tightened. Please let there be no more whiff of Diesel around the car. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #399894 10th Aug 2016 7:04am
