Home > Technical (L322) > Key fob battery fault |
Brooksy Member Since: 18 Sep 2015 Location: Caister-on-sea Posts: 23 |
What brand batteries are you using ? I had the same prob. Got a battery from local motor factors, fitted it and still got same message.Then fitted a Duracell battery and worked fine |
13th Feb 2016 4:10pm |
Phi. Member Since: 11 May 2015 Location: Halifax Posts: 14 |
Hi Brooksy
13th Feb 2016 7:40pm |
Put new energiser batteries today- did the trick. Working fine now.
22nd Feb 2016 7:00pm |
dutchhome Member Since: 26 Feb 2016 Location: Delaware, USA Posts: 13 |
How are you guys swapping the batteries so easily? I only was able to change mine because I transplanted the guts to a new plastic FOB. I had to desolder the old battery and solder in a new one. Or does the UK have different FOBs than we do in the states? |
26th Feb 2016 1:07pm |
Sounds like you have a different fob to UK spec. To replace the batteries take less than a minute.Plenty of how to videos to show you how they are fitted.
26th Feb 2016 1:49pm |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
Once you replace the battery (2011 model, 2032 battery), you need to lock and unlock the car using the remote to clear the error message. Check YouTube for how to open up the remote 2011 Vogue TDV8 4.4
26th Feb 2016 5:55pm |
For reference, on my 2009 RR, I had to do something similar to these videos:
26th Feb 2016 6:38pm |
