Home > Maintenance & Mods (L322) > scuttle panel renovator
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi everyone, tried a search but can't find the thread.
I'm sure pete haylands wrote about it.
Theirs a solution he bought that brings the scuttle panel up nice, in front of the windscreen, only mines looking a bit tired, would like it a bit better.
anyone any idea what it is please.
greg Thumbs Up
Post #374277 26th Feb 2016 11:06am
was it peanut butter?
edit,
http://www.fullfatrr.com/forum/topic24902....nut+butter ... - .- -.
Post #374278 26th Feb 2016 11:08am
gregdav
Stan. Bow down Bow down Bow down
that's the thread I was looking for.
You are amazing. Very Happy
thank you.
greg.
Oh and thanks for moving the post. Embarassed
Post #374280 26th Feb 2016 11:17am
Thumbs Up ... - .- -.
Post #374282 26th Feb 2016 11:26am
Peanut butter or any other oil will bring it up OK for as long as the oil stays on it or until the next wash...
I recommended this stuff
http://www.ebay.co.uk/itm/Gtechniq-C4-Perm...SwmrlU08~6
Not cheap but does work, I did all the plastic on my old XC70 that had really gone off, it still looked like new two years later.
15ml will do all the black plastic on a FF about twice I would have thought... it really does go along way, just make sure you clean the plastic well first... Pete
Post #374285 26th Feb 2016 11:49am
this is a bit cheaper Pete, and you can have a sandwich after you've done the panel,
Mr. Green ... - .- -.
Post #374288 26th Feb 2016 12:00pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Peanut butter Shocked
I appreciate the oil will work but I suspect any animals in the vicinity will take to licking it off in short order.
I use the Meguires product designed for the purpose. Used to bring my P38 door handles up a treat.
I have actually used it on the FF scuttle panel, post Autoglass Neanderthals putting in a new screen recently, and it works very well. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #374290 26th Feb 2016 12:27pm
The thing with the Gtechniq C4 Permanent Trim Restorer is that you do it once, that's it... job done... forget it for years....
Anything else will work for a while.... WD40, household polish, shoe polish, peanut butter, palm oil, and any other make of trim cleaner/polisher...
I suppose it depends on how much you like polishing... Thumbs Up Pete
Post #374294 26th Feb 2016 12:35pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
+1 On the C4 Techniq. Great stuff! Costs a few quid but you only need to apply a few drops on a cotton pad. I did mine like 10 months ago and they are still shining bright. Will probably last years. 2002 L322 V8
Post #374300 26th Feb 2016 1:28pm
gregdav
Thanks for your help and advice lads?
I only remembered a thread by pete sometime ago, as I wanted more of a permanent solution.
The c4 stuff looks like the stuff I will go for.
Cheers. Greg. Thumbs Up
Post #374365 26th Feb 2016 6:45pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Hot air gun works a treat also as it draws the oils back upto the surface of the scuttle. Just be careful not to get it to hot
Post #374374 26th Feb 2016 6:59pm
gregdav
Hi JPS.
I've seen that trick done on you tube, but reckon I'll be safer with the c4.
cheers greg. Thumbs Up
Post #374376 26th Feb 2016 7:05pm
