Home > Technical (L322) > 3.6TDV8 Brake Caliper Confusion...
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
At what point did the L322's come with the big 6pot Brembos? Is it only the 4.4's that came standard with these?
Assuming this is true and the Brembos are an upgrade on the 3.6.. What is the standard disc size on the front and rear?
And is it single pot calipers on the rear and 2pot on the front?
Been desperately trying to google this info but can't seem to find it. Single pot rears just don't seem enough in my mind.
Thanks
Post #374107 25th Feb 2016 4:01pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
They initially came on the super changed only then on the 4.4v8 log burners.
Post #374111 25th Feb 2016 4:17pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
ak Craig, he did this one of mine luckily as it can stop so differently to the standard as i found out last week when aTT cut in and stopped at 70 in front of me Censored it stopped better than his did thank god then i did have a quiet word Whistle _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #374116 25th Feb 2016 4:43pm
JPHC
Cool, thanks guys. So worth the upgrade then. Noted.
So if the standard rears are single pot is it not worth upgrading them also? Or is the bias so front heavy it doesn't really matter?
Are the standard fronts 4pot? and do you have to get bigger discs with 6pot upgrade?
Cheers boys
Post #374127 25th Feb 2016 5:15pm
6 pots only came on the 4.4 TDV8 and the 5.0 SC. What car have you got at the moment?
I disagree with Scotty, in theory they are better, but in practice there is not that much noticeable difference between the 4 pots and 6 pots in normal use, having had both the 3.6 and 4.4 they both stop fast when you stamp on the anchors. Im sure there is a difference, but you would have to get the tape out to tell what it is.
If you have the 4 pots at the moment then there is little point in upgrading to the 6 pots just for the sake of it (plus the pads are a lot pricier)
The 4 pot brembos are standard front fitment on the 3.6 and 4.2 sc as are single pot rear callipers. It doesn't have brembo rear brakes, they are TRW callipers on the back. It is the same setup as the 4.2 SC.
Even the 4.4 and 5.0 only have the six pot brembos on the front and single pots on the rear. The fronts do the majority of the braking in any case so it makes sense for the braking force to have a forward bias.
so to sum up
3.6tdv8 and 4.2sc = 4 pot brembo and single pot trw rear
4.4tdv8 and 5.0sc = 6 pot brembo and single pot rear (not sure on the make but they are different from the 3.6) There is nothing that can't be fixed with a hammer😜😜
Post #374134 25th Feb 2016 6:15pm
JPHC
Excellent info. Thank you very much mate.
I wonder if the need to upgrade is stronger after an increase in power...hmm..Guess we will have to see!
(The 6pot's do look nicer too lol)
Post #374139 25th Feb 2016 6:46pm
Could be, bt don't forget it als limits choice of wheels. All 20" are fine but only 1 19" fits. There is nothing that can't be fixed with a hammer😜😜
Post #374149 25th Feb 2016 7:44pm
To save the confusion...
Scott has 4 pot Brembo�s but........ With upgraded drilled & grooved disks so stopping will be top draw Thumbs Up
Pre 2010my cars i.e. those fitted with 4pot Brembo�s CANNOT be fitted with 6pot Brembo�s as a direct fit replacement! As the holes in the hub castings are too small! Yes you could change the castings but they are uber expensive thus making the job un-economic...
Hope that helps? Thumbs Up
Post #374159 25th Feb 2016 8:17pm
^learning experience. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #374172 25th Feb 2016 9:03pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Mine must be an inbetweener then
its 59 reg MY10 3.6 TDV8 but I don't think it has brembos at al..! Big Cry Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #374206 25th Feb 2016 11:01pm
^ wasnt that the year they went to normal brakes... ... - .- -.
Post #374210 25th Feb 2016 11:03pm
Yes, the post facelift 3.6 cars had standard brakes There is nothing that can't be fixed with a hammer😜😜
Post #374213 25th Feb 2016 11:18pm
Im pretty sure from memory........ Rolling Eyes Shocked Rolling Eyes Yours would take the 6pot Brembo�s Ash Thumbs Up
Post #374227 26th Feb 2016 12:34am
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I think Ash is in the exact same situation as me. Mine is a 2010MY on an 09 plate
The brakes on mine do not feel as good as my old 02 V8 and certainly no where near as good as the 4.2 56 Supercharged I drove the other day.
6 pot Callipers are more than a bit spendy though.....
Post #374281 26th Feb 2016 12:19pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
I too have this issue - a 2010 3.6 with the 'stock' brakes.
I was wondering as to whether one could fit the 2005-2009 4-pot Brembos to these easily??? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #374362 26th Feb 2016 7:39pm
