Home > In Car Electronics (L322) > Nav Voice Volume
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Nav Voice Volume
I don't use the Nav very often but since I got the car, when I do use Nav, I find that the voice is very quiet in comparison to the radio volume being normal.
On my OEM X5 system I could easily adjust the nav voice volume as I can on my vaarious Tom Toms but not on the Fatty it appears.
At least I can't find anywhere to adjust the volume so any advice would be much appreciated. It's a touch screen from 2006. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #374270 26th Feb 2016 11:09am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
while it is speaking use steering wheel buttons
Post #374272 26th Feb 2016 11:17am
V8Noise
Thanks lighthouse. I'll give that a go.
I'm guessing it only increases the nav voice volume and not the radio/CD/iPod volume at the same time. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #374291 26th Feb 2016 1:29pm
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
this is done via System Volume Settings
as detailed in the handbook, page 313 in mine
To access the volume set up menu, press and hold the Tone button until the volume set up menu is displayed.
The icons to the left, allow you to choose a setting to adjust (AVC, INFO, NAV, Phone and Voice).
The boxes to the right of the icons show the values currently set for each option.
The bar graph and the +/– icons are used to change the settings and show the changes.
hope this helps
Phil various other LR's this one is still the best
Post #374293 26th Feb 2016 1:33pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I asked this some time ago r the MY10 variety - still not worked it out
(and its not volume up while she is giving me incorrect driving advice..!)
IGNORE ALL THAT - it's been a long week. My issue is with parking sensor beeps volume..... Shocked Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #374389 26th Feb 2016 8:41pm
''My issue is with parking sensor beeps volume''
not sure if you have one but thsi can be adjusted with the iidtool.. ... - .- -.
Post #374430 26th Feb 2016 10:45pm
comports
I do indeed Mr Stan (IID BT) - I thought I tried with that but had no luck - Will have another look though Thumbs Up Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #374432 26th Feb 2016 10:50pm
i've turned mine up to full volume ..i have no excuse for backing into something now.... Laughing ... - .- -.
Post #374433 26th Feb 2016 10:55pm
V8Noise
Phil,
Give that man a ceeeegar.
All sorted via handbook instructions. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #374513 27th Feb 2016 1:05pm
