![]() | Home > Technical (L322) > L322 2006+ Air compressor overhaul |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
Similar to cheap Chinese winches... you could try heating it up as the alloy expands more than the steel... think I'm at about a 50/50 success rate... good luck |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
FORGET all overhaul kits and parts for this horrible Hitachi compressor, special the piston makes problems, buy a new one or an AMK, only the WABCO (2002 to 2005) is one time able to refurbish, also there you need at the second time a new cylinderhead.
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 167 ![]() ![]() ![]() |
Pete, sorry the crank AND armature shaft which I need to separate are both steel so no differential expansion possible. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
