![]() | Home > Maintenance & Mods (L322) > TDV8 EGR maintenance |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
Steve there's s product called emergency tape, could handy to have in the toolbox. Paul |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Paul, If you PM me your email address I will send over the WSM procedure in removing. It indicates that the wiring is completely out of the way when it say to remove the intake manifold, but if you bring the wiring forward it covers the front 90 degree hoses (the sections sticking out left and right of this picture But as I say if you lift the back up and then move it left and swing the right out, then move it right and a bit of a wiggle and the whole thing will lift away. It's just the size of it that makes it awkward Regards Mark 2012 Westminster GONE - 2007 Java Black FF Vogue, with Ivory interior |
austeve01 Member Since: 17 May 2015 Location: Flagstone, Qld Posts: 12 ![]() ![]() ![]() |
Thanks Steve,
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 53 ![]() ![]() ![]() |
Out of interest, what is the part in the red circle? |
leusfx Member Since: 24 Jul 2018 Location: prague Posts: 25 ![]() |
The air intake manifold has a variable intake valve (a.k.a Intake manifold plenum chamber runner control actuator) which allows the two sides of the manifolds to be connected/separated to balance the airflow. |
Thanks, useful. When I have pressurised the small hose from the air box it sounds as though air is either rushing through that part, or leaking. I presume it is meant to be sealed. Will have to sort a smoke test I suppose. |
