Home > In Car Electronics (L322) > Fitting intravee what do I need
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
I have intravee in my 322 but cant remember what was involved, I have the following and need to know what else to buy.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #373758 23rd Feb 2016 8:09pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Johnny
Its been a while but essentially the intravee and KCA replace the cd changer on the glove box.
Should be a straight plug and go and when you turn on the stereo, select CD and you should get the tracks/playlists show up on screen to select. Just use the controls as if it were a cd mate...
(obviously you have to plug the iPod or iPhone in as well) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #373778 23rd Feb 2016 9:59pm
comports
oh - there are also some settings in the Intravee menu that will allow you to control other things.
You can set up follow me home lights, mirror fold/unfold and other that I can't remember.
Do a search for Intravee and all will become apparent...
Hope that helps Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #373779 23rd Feb 2016 10:00pm
JohnnyDangerous
Thanks Comports, I get that and the extra features etc I just need the part number of the extra part I need and maybe some idiot proof instructions One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #373984 24th Feb 2016 8:51pm
comports
Sorry Jonny - what extra part..?
You should have the intravee II and the KCA420i - the CD loom plugs straight into the KCA I think and the Intravee plugs into the KCA unit. The KCA should have an iPod lead - thats it from memory - I don't think the iPod charges though from memory Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #374002 24th Feb 2016 9:38pm
JohnnyDangerous
I dont have an intravee2 !!!! One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #374015 24th Feb 2016 10:41pm
comports
apologies - I thought you said you had intravee....
try this one Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #374022 24th Feb 2016 11:08pm
comports
You can also buy new from ToysInYourCar.com - same price Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #374023 24th Feb 2016 11:09pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
John,
Their a easy job, ive got the intravee in mine, ipod and 6 disc changer, i am using a well old iphone though as they dont like the newer ones.
The white alpine unit in the pic is a switcher unigt allowing 2 devices IE the ipd and a changer.
My brain like ur pictured is under the pass floor carpet, the intravee is behind the side panel so in can update plug in etc
Post #375393 2nd Mar 2016 9:27pm
cliffy
Theres a adapter wire knocking about u can sometimes pick up but u may need a bit of loom to do the conversion as well, its been ages since i done mine but ik managed to source the direct plug in loom that will connect ur intravee to the car then the intravee plugs into the alpine brain unit to allow coms and a splitter
Post #375395 2nd Mar 2016 9:28pm
