Home > Technical (L322) > went in for oil change, came back out with AIR SUSP INACTIVE |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
Possible that it's a slightly flat battery if they've been in and out of it all day - that sometimes throws up random messages. |
22nd Feb 2016 8:07pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
That message used to appear occasionally on my 2004 car. The suspension seemed to be working fine and the message generally didn't reappear when the ignition was switched off and then on again after an interval. Let's hope that is what you have and the message is away in the morning.
22nd Feb 2016 8:09pm |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
I do hope it goes by tomorrow!, will any OBD reader be able to clear the message or does it need to be an IID tool? |
22nd Feb 2016 8:14pm |
I think that if the fault goes away, the message should clear.
22nd Feb 2016 8:15pm |
Thanks Alistar, just presuming there is no fault and either battery or something has knocked a message into the ECU to stop the air susp from working at all that all it will need is a fault clear. Heres to hoping. |
22nd Feb 2016 8:19pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
When I got my 2002 I used to get the odd ASI bong, and sometimes it was after a long go at trying to pump up the reservoir. Like when it was on its belly...I can't remember how I fixed it, but the long term was, I changed the suspension pump myself, it's in the boot under the wheel well . It was about £330 and took about 1/2 hour. Quite easy. Just follow an online step by step, or look in the wiki. Never had pump issue since. I had also changed the battery. But that seems to be going bad again, but not throwing ASI though. I do now have a RSW alcomms fault reader.
22nd Feb 2016 10:03pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
Generic OBD readers will not clear EAS faults, they only work with emission faults...
22nd Feb 2016 10:07pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 315 |
EAS faults are best to clear (2002 to 2005, BMW-time) with INPA Ediabas Software from BMW, each BMW dealer can connect it on OBD and will help you for less than the official RR.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
22nd Feb 2016 10:20pm |
well its still not working
23rd Feb 2016 6:20pm |
Did you run the car - or charge the battery ?
23rd Feb 2016 6:47pm |
Car has been run around today a fair bit, so would of thought the battery would be OK now, i might give it a charge tomorrow though to be on the safe side before ordering anything.
23rd Feb 2016 7:01pm |
Might be worth clarifying with them exactly what they did with it.
23rd Feb 2016 7:05pm |
Pop back and get them to read the codes and try to reset it, they should have something that should do it..
23rd Feb 2016 7:06pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Also have a look at the height sensors. Maybe one has broke or gone over if it's been on a lift. |
23rd Feb 2016 7:39pm |
