![]() | Home > Technical (L322) > ZF 6HP26 Gearbox Oil |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
"The one thing that has caught my eye is that on the same spec sheet it lists it as being a compatible replacement for the LT71141 used in the 5 speed box and I was under the impression that they were totally different oils! "
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1424 ![]() ![]() |
Buy the genuine. Buy once. ZF have replied to other owners of ZF boxes explicitly stating why they recommend a specific oil and i've pasted it in this forum in the past (i'd need to go looking for it) They also comment that it costs them a lot of £££ for the stuff as it does us. V8 or else ... |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
Advanced Factors do Meyle stuff which is supposed to e the same for under £10 a litre. Been discussed on here before. |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
I got mine from here, http://www.lrparts.net/catalogsearch/result/?q=lifeguard+6
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I would personally only use the ZF Lifeguard 6.......its the correct oil. I used Mackies when I had my SC to change the oil, I also changed the multiplug seal at the same time as a precaution......it makes sense as you need to drop the sump to change it and sods law it will leak at some point..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 49 ![]() ![]() ![]() |
I've used the millermatic DM multiple times in all of my 6hp trannys that I've owned. This includes the XK, l322, DB9 etc.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
AFAIK It's not about the oil, it's about the additives... the manufacturers make an oil to a particular spec and that oil advertised is the same spec... a bit like everyone makes a 5w-40 motor oil... ZF specified what additives should go in the oil... these won't necessarily be in the cheaper oil... ipwn's experience is probably what will happen 99% of the time if you use the cheaper oil but...
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
in your video you don't mention about monitoring of the oil temperature when filling , I thought this was a very important part of refill levels ? 2007 tdv8 se ,stornaway grey |
It can't be that critical, the thermal expansion of oil is not a lot... a 20deg C increase will give a volume increase of just over 1%, negligible in the great scheme of things.... |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
The running moves the fluid around as well. Recently did my 6 speed BMW auto box new pan with filter in and oil, could only get 2 of the seven litres in cold then more each time I ran a heat cycle. Temperature is way more than 1% |
Yes the official version is to get it up to temperature and drain out the excess. I stopped bothering as it wasn't much difference between hot and cold. The ZF also comes slightly overfilled from the factory as it is by around 400ml anyway so Ive never seen it as a problem. |
