Home > Maintenance & Mods (L322) > Whistling brakes. Grease em up?
pld118
The brakes have started whistling in the last 6 weeks. Could be the colder weather?
New genuine LR brake pads fitted last June and never a peep until now. Strange.
Will grease them and see if that resolves it.
Post #373231 20th Feb 2016 8:09am
Mine did it for a while a few thousand miles after fitting them. Then just stopped.
A dab of grease would t hurt, but use the ceramic stuff not copper as it's supposed to be better for abs systems.....apparently There is nothing that can't be fixed with a hammer😜😜
Post #373232 20th Feb 2016 8:24am
whistling brakes are happy brakes... Mr. Green
strip down and clean,could be grit or excess brake dust and as you suggest ryan, grease them up....i know pam drives it mostly so please resist putting the grease on the side that goes onto the disc.. Laughing Wink ... - .- -.
Post #373233 20th Feb 2016 8:41am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I'd have thought that putting grease on your brakes was not a good plan if you want to stop quickly Whistle
Post #373266 20th Feb 2016 2:34pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Been running ebc greenstuff front/rears two weeks bedded in beaut on thes huge brembos Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #373267 20th Feb 2016 2:52pm
pld118
stan wrote:
whistling brakes are happy brakes... Mr. Green ...so please resist putting the grease on the side that goes onto the disc.. Laughing Wink
Laughing
Cheers for the replies. Thumbs Up
Post #373290 20th Feb 2016 4:52pm
pld118
Well, the 6 pot brembos are a bit different to the 4 pot brembos that were on the SC. There's a bolt bar type thingy in the middle, additional to the 2 standard pins. That momentarily flummoxed me when trying to slide out the pads after removing the 2 pins Laughing
The pads were Jurid and they seemed massive. Only did one side today as tome was against me Whistle
Post #373435 21st Feb 2016 7:07pm
They are big! But fundamentally the same. I presume the big bolt through the caliper is to stop them spreading when you brake. Thumbs Up
I'm pretty sure Jurid are part of Honeywell along with bendix and are oem suppliers to a lot of manufacturers. There is nothing that can't be fixed with a hammer😜😜
Post #373465 21st Feb 2016 8:16pm
