Home > Maintenance & Mods (L322) > transmission fault
lawsey
England 2015 Range Rover Vogue SE SDV8 Corris Grey
transmission fault
SOD's law or bad luck??
My 07 69,000. Just had car serviced at main dealers. The following day I get a transmission fault warning light. Is there anything they may of done that caused this issue. Only came on once then went off again after approx 400 mtrs. Only just had the car washed when it happened anyone have any ideas???
Taking it out for a run now to see if it repeats
Post #373346 21st Feb 2016 8:45am
miggit
Might be water in the ECU, was it an external wash, or did the engine get done as well? Whistle Only you'll soon discover that the Range Rover doesn't actually like water, especially under the bonnet Shocked If a wet engine is the cause, it should dry out and hopefully all will go back to being normal Wink
And if you feel the need to clean the engine bay then might I suggest some WD40 and a rag, it will look shinier for longer and the car will love you for it Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #373347 21st Feb 2016 8:56am
lawsey
Up date..
Took the car for a two hour run this morning,when selecting drive everything works as it should from 1-6 and back down again, tried it in sport and box went from 1-2 then going to 3 transmission fault warning appeared. the box switched itself over to drive with the lever still in the S position. The fault then went?? tried driving in D again and everything worked??
any suggestions??
Post #373388 21st Feb 2016 2:22pm
dingg1
yes - stop worrying about it - its fixed itself
Post #373397 21st Feb 2016 3:37pm
miggit
Combination of Roverphobia and water, it's all dry now, just watch where you point your hose in future Shocked Wink Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #373492 21st Feb 2016 10:28pm
