Home > Maintenance & Mods (L322) > LED fogs mounting.. |
AzizRR Member Since: 08 Feb 2016 Location: Muharraq Posts: 54 |
Hello there, If i may ask .. Im looking to install Morimotos LED fogs or osram ones ..
13th Feb 2016 1:47am |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Hi, have a look here: http://www.fullfatrr.com/forum/topic33047.html?highlight=drl+fog
13th Feb 2016 9:17am |
Thank you for you reply, i have read this post before, but morimoto led fogs might be a lot easier job as it only has the led fog without the DRL wiring, plus all i need to know is a way to mount the fogs because they use different brackets.
13th Feb 2016 9:45am |
I'm not sure about the fit, since I have a MY02 car. But, by the looks of them, they might fit without to much of a hassle, though someone else can probably better comment that. I had to made a custom fit for mine, as you probably red in the thread I mentioned earlier, but it works like a charm.
13th Feb 2016 10:53am |
can you explain the IDD tool and the hot/cold bulb thing.. i hear people talking about it but i have no idea what is it.. ' newbie ' |
13th Feb 2016 7:04pm |
The Iid tool is a tool to connect to the obd port of your car, either via bluetooth or by cable. It can read and clear all sorts of errors/messages that pop up, you can use it to read the EAS (air suspensoir) and calibrate it. Also you can config lots and lots of settings, best explained here: http://www.fullfatrr.com/forum/topic12418.html?highlight=iid+tool.
13th Feb 2016 8:14pm |
Thank you very much!
13th Feb 2016 8:16pm |
They're brighter than stock fogs thats for sure but what matters is the look , those gives the OEM look just like most recent models cars and even better. |
16th Feb 2016 1:49pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
So they are a plug and play into the stock bracket?
16th Feb 2016 1:53pm |
Their support told me that this fog should fit l322 pre facelift as the brackets are the same even the bulb.
16th Feb 2016 3:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
if you look at my thread re my 'conversion' you will be able to decide if these will fit the 2006-2009 model years...
16th Feb 2016 3:39pm |
Aziz...2010 pre-facelift or 2006 pre-facelift?
16th Feb 2016 4:31pm |
The 2010 pre-facelift..
16th Feb 2016 4:43pm |
if yours is a 2006-2009 then those lights will not fit unless you fettle them...the standard fogs have 3 mounting tabs and those in your link have 4....
16th Feb 2016 5:39pm |
