Home > In Car Electronics (L322) > Siemens aerial
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Siemens aerial
Hi all. Changed side lights bulbs to match Xenons today and on removing grill I found an antenna from a tracker , ok didn't know it had one fitted buteft well alone. On removing drivers side headlamp there was a Siemens aerial???? hanging loose
Question is , what's this for and where should it be bolted / screwed to please ?
Thanks in advance 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #372485 15th Feb 2016 4:11pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Censored Check the Mrs phone to see if she has a tracker app on it asap Whistle
You are being watched Shocked Shocked Shocked
Post #372528 15th Feb 2016 6:52pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Interesting but on my old L322 I found the tracker unit (that i did;t know existed) under the rear right cubby box where the rear fuse board is. Have a check in there and you may find the main eco unit as well.....
It's just like Christmas all over again Rolling with laughter Ash
2016 SDV8 AB
Post #372532 15th Feb 2016 8:05pm
