Home > Technical (L322) > Fan noise
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Fan noise
Whenever i turn left i get a noise that sounds like a fan catching the noise varies on when it happens as sometimes it's as soon as you start to turn and other times at 1/4 turn but it never does it when stationary ,i've had a look under the left arch as that's where it sound like it's coming from and can't see anything Exclamation L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #372157 13th Feb 2016 2:10pm
Does the noise vary with speed, i.e. change in pitch according to speed, if it does it sounds like the tyre is catching on the inner wing somewhere...
If not.... well, not to sure... sorry... Pete
Post #372168 13th Feb 2016 4:04pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
check the dust shields on the back of the discs, they go rotten and touch the disc when turning, usual problem and definitely worth checking.
Post #372240 14th Feb 2016 12:16am
Ivor
there's no change in speed which has me thinking of a fan I guess another session looking like i've been run over is needed L322 2008 vogue
Post #372256 14th Feb 2016 1:51am
Put the wheels on full lock both ways and the suspension in off road height, then get your head in the wheelarch, you should be able to see if the tyre is catching on something, it'll be the rear of the left arch or the front of the right arch... that's still my best guess... Pete
Post #372265 14th Feb 2016 2:37am
Ivor
thanks ,snow and Rugby stopped anything happening today l L322 2008 vogue
Post #372341 14th Feb 2016 6:17pm
