![]() | Home > Technical (L322) > 4.4 TDV8 Battery Conditioner |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
I went to start the TDV8 this morning in the garage but the battery was flat on it, have currently got it disconnected and on charge but have been pondering the idea of a battery conditioner for it to leave connected all of the time.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Use it regularly with no issues (connected to a CTEK). First time I used it, I found that my 12S socket was goosed so had to replace it, no great drama though. Previous cars:
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
David, i have a CTEK i leave on our summer toy which is fab... Mine goes into the fag lighter socket and keeps the battery perfect all through the winter |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Just found photos in an old email I sent to Martin Sorry I can't rotate it !! |
Brilliant, thanks guys. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
is a good idea, have had one in the boot with the Ctek and it gets plugged in when I'm away in a different car, also use it as a supply when we go to lemans as you can plug it into the tow socket and use the ctek as a power supply so you don't flatten the battery when listening to the radio etc.... There is nothing that can't be fixed with a hammer😜😜
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
It is perfect for me because I drive into the garage so it is very difficult to get under the bonnet to get to the battery.
Don�t think it will make any difference as long as your battery is charged... Only if your battery is under and then it will probably blow the CTEK up! |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
This is probably a very daft question��..
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
I have an Optimate for my bike. On the bike is a lead which terminates in a plug with a waterproof cover, the Optimate lead plugs into this. Rather than going to the expense of having a 12s socket fitted, what about a similar set up on your car leaving the plug in a convenient location. I'm sure you will be able to buy one. |
The 13 pin mounts on the large armature, but the Ctek comes with a waterproof plug you could leave permenantly connected in the rear boot cubby. There is nothing that can't be fixed with a hammer😜😜
What would the implications be in finding the permanent 12v supply in the boot to wire into. Would it be in the rear right corner and would he need the LR harness to do it? |
