Home > General (L405) > Advice re factory misbuild
Page 2 of 3 <123>
wealy
May will soon come any.....
Go for it
Post #369682 31st Jan 2016 9:53am
JMDT
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Corris Grey
Thank you all for your advice. Have agreed with the dealer/JLR to have a new one built and in the meantime I get to keep the existing one. End April currently scheduled build so not long. I think a sensible outcome so not disadvantaged. A little inconvenience but problem sorted.
Post #371475 9th Feb 2016 3:09pm
I think that's a fantastic result - you get a newer car, for not much inconvenience Thumbs Up
Post #371489 9th Feb 2016 4:00pm
Isn't there some way you can test drive your new car before you accept it, don't you get the opportunity to do what the dealer should have done, a proper PDI and highlight issues before you sign for it...??? Pete
Post #371494 9th Feb 2016 4:20pm
JMDT
You are right. Should have been picked up on the Pdi.
I picked it up very quickly driving it at night. First response from dealer was that they were fitted but might need a software tweak and to bring it in for inspection. That was before inspecting the vehicle. On inspecting the vehicle, they tried to pursuade me that they were fitted as it was on the build sheet. On insisting that they were not, they ran a systems diagnostics which confirmed that they were not fitted despite the build sheet saying they were. But I knew that anyway...
My point is they checked it to build sheet but not the operation of them. I guess that's reasonable although I was disappointed in bringing it back the error was not immediately confirmed following the inspection of the problem rather than me insisting they had also got their initial diagnostic wrong after raising the problem with them.
The fiitment of the wrong steering wheel I picked up at handover and they confirmed that could be changed. The other faults I picked up within 24/48 hours of delivery and were fixed quickly.
The fuzzy background on the parking camera screen remains an issue. But I think that maybe a bigger issue beyond my car. I will try and screen shot it.
Post #371509 9th Feb 2016 5:44pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I heard recently there is a nose weight limit on the deployable towbar which excludes many normal twin axle tin tents - might be worth checking if that your use. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #371526 9th Feb 2016 7:27pm
JMDT
Ajac8. Thanks for tip re towbar. It is for a boat (6.5m RIB) so I will check weights. Good tip.
Post #371563 9th Feb 2016 9:22pm
It's the off road weight that's limited with the powered to bar - on road is fine as is nose weight - as long as 150-200kg is sufficient......
Post #371571 9th Feb 2016 10:17pm
JMDT
Thanks for that. My towing on road. But good to know.
Post #371576 9th Feb 2016 10:43pm
JMDT
Got my replacement today... The sun roof blind didn't work properly, so left it at the dealer.. but soon resolved as something had been left in place that shouldn't have been (a shipping magnet in the centre of the blind) and they then drove it out to me. Saved me another trip but shame it hadn't been picked up as part of PDI. However, will have to take it back in to sort out the drivers door as the soft close does not work. On the positive side, got 9500 miles of "free" motoring in the original. It will make a fantastic used buy for somebody...
Post #389363 30th May 2016 1:53pm
It's great that they did the right thing re the mis-build - but you really would have thought they'd have PDI'd the new one to death before you arrived Rolling Eyes
Post #389373 30th May 2016 2:49pm
caymanblack
Get some pictures up, i love the waitomo grey.
Post #389374 30th May 2016 2:54pm
Paul J.
The driver's door soft close is disabled at the factory, and should be enabled during the PDI. It is a simple procedure to switch it on. The same oversight occurred with me.
Post #389381 30th May 2016 3:14pm
JMDT
Paul - that's helpful to know. They did say it was a quick fix re programming... Current: L460 Autobiography D350 2023, Defender D240 HSE 2020, Defender 110 Adventure 2015, Defender 90 XS 2012, Lightweight Ser III 1975, Aston Martin DBS Manual 2008
Previous: L405 SVAutobiography Dynamic 2018, L405 SDV8 Autobiography (2016 x 2, 2015 x1), 110 V8 1989, Discovery td5 ES Series II 2000
Post #389386 30th May 2016 3:36pm
JMDT
Light is poor but here is a shot...
Post #389390 30th May 2016 4:02pm
Page 2 of 3 <123>
