![]() | Home > Maintenance & Mods (L322) > Starter grind |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
Can you access the top E12 bolt for the starter motor from the top of the engine bay?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8558 ![]() ![]() ![]() |
I don't think you can get at it from the top, if you remove the exhaust heat shield you can get at it from the rear of the right side front wheel arch, it's easier to unbolt it and then remove the wiring, best to undo the other end first, or disconnect the battery...
I called some |
Most irritating bit is that the old battery was prob fine, although it was 2 yrs old. 2004 L322 V8 |
The Range Rover one has a vent to it, I expect if the BMW one is different it won't have the vent, can't see the fitment would change, I know the gearbox casings are different but the bellhousings are the same AFAIK... Pete
