Home > Off Topic - Other Cars > P38, tech question for former owners
miggit
Hi all, my pal with a P38 is having trouble with the lights on his hevac display, he's put new bulbs in, but it's really dim Shocked and not controlled by the instrument dimmer........ is there any way of turning it up? like the secret menu in the ffrr.
The lights are working as you can just make them out in the dark, but this is no good to man or beast in the daylight Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #371114 7th Feb 2016 5:48pm
dhallworth
Unfortunately you can't change the brightness on the P38 display. If it's dim after new bulbs then you'd need to be looking at changing the whole panel Sad
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #371154 7th Feb 2016 8:50pm
RR2008HSE
Sorry to point out the obvious, but he did out in the correct wattage bulbs, right?
Post #371183 7th Feb 2016 10:54pm
From memory (long time since I’ve seen one!) they used to get stuck in “night dimmed mode” a curse of the BECM!
Post #371201 8th Feb 2016 1:13am
johnboyairey
Craig could be right, but I did mine long time ago, and bought a set of bulbs on eBay. I think there was one I couldn't change, I think there were 5 in total. And one was very different?
Maybe try a battery reset, with lights off of course.
And keys in you hand, or you lock yourself out! Oh, and read up the key code lock out 'beep of doom' before doing this too.
Post #371220 8th Feb 2016 9:59am
miggit
Thumbs Up Cheers chaps, I'll pass on the wisdom Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #371293 8th Feb 2016 6:07pm
p38arover
Australia
Look at my pix here: http://www.rangerovers.net/repairdetails/lcdlights.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #371375 9th Feb 2016 8:21am
