Home > Maintenance & Mods (L322) > Rear Brake Caliper sticking |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3783 |
Well I just noticed that my offside one is sticking, had the same problem on the last car and it seems a common enough problem. My default position is to get my local indy to replace both rear calipers with new ones, then its definitely fixed and the problem goes away permanently, well for a good few years at any rate.
6th Feb 2016 1:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Unusual Geoff on the later cars as the callipers are different on the 4.4 & 5.0... |
6th Feb 2016 9:54pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
6th Feb 2016 10:03pm |
Unusual - just my luck, I bet that the calipers are not only different but more expensive as well
6th Feb 2016 10:23pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
One of mine was sticking last week, the wheel was getting VERY hot. Took it off and it was VERY reluctant to move back in. Gave it some white grease spray under the rubber seal and after a few minutes it was as free as it should be.
6th Feb 2016 11:53pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
Check its not it the pads seized in the caliper carrier also.
7th Feb 2016 8:26am |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
Rear calipers !
7th Feb 2016 9:35am |
7th Feb 2016 12:24pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
I stripped and replaced the seals on my offside rear too. It lasted a year, but I ended up replacing both calipers last weekend.
7th Feb 2016 5:01pm |
Gents, your all talking about changing 06-09my rear callipers and yes they are a well known issue but Geoff has a 5.0 so has the later Brembo setup & different rear callipers to your cars!
7th Feb 2016 5:09pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
I have to laugh at all those who go and splash out on new calipers because they are sticking,you must have money to burn.Maybe there is an issue with the calipers but most of the time it is just sticking pads caused by roaddust and brake debris or a little spray behind the piston rubber.My friends '09' plate had the same,just a good clean out and maintenance,been fine since .If you ever pun new pads in just make sure they are not tight,i have put a good file or grinder on lots that are too tight,you will only get sticking brakes if you force them in ! |
7th Feb 2016 7:13pm |
Ive been busy this afternoon, fitted the spare wheel lifting straps (excellent) and had a quick play with the sticking caliper but I didn't do much really as it started to rain, I have not yet given up hope and Craig I am grateful that you pointed out that I may have been jumping to the wrong conclusion. Geoff |
7th Feb 2016 7:51pm |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
Urg rear calipers, same as d3 what a nightmare they are.
8th Feb 2016 11:37am |
Is yours a 3.6 or a 4.4 MachineHead? |
8th Feb 2016 12:33pm |
