Home > Off Topic - Other Cars > [SOLVED] Mechanics Advice Needed - Ford KA breakdown?
Trying to figure this one out.....
My son's Ford Ka (Endura) broke down on the motorway on Friday. Loss of power (car would start but die under any load) and loss of coolant big time (nice trail on the hard shoulder!)
Me thought, head gasket, so set about removing head after supplying mylsef with a head gasket set from Europarts.
Stupid car to take apart, especially getting the inlet manifold off Evil or Very Mad
I did a compression test and NO1 cylinder no compression.
Once rocker cover removed I spotted the power problem, pushrod was off its rocker Smile
Head off no problems with gasket, no problems with condition of pushrods, valves look OK but will have NO1 valves out to check them.
Car has never used any coolant in the past. Stupid Ford Ka has no temp guage, think it might pop up a light if it gets too hot, but son is not mechanically minded so probably didn;t spot this if it did happen.
Trying to figure out cause/reasons. Thinking maybe water pump has packed up causing overheating of engine causing pushrod to jump off its rocker.
Any thoughts/suggestions? .
Post #371134 7th Feb 2016 8:18pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
I would check headgasket closely on NO1 cylinder. Water ingress into cylinder could of forced push rod out of rocker/
Post #371171 7th Feb 2016 10:58pm
Thanks Brian
I'll have a closer look.
I'm trying to figure out if the two issues (lost coolant/pushord) were related or one caused the other?
From what you say, which makes sense, I'l need to give the cooling system a good look over .
Post #371193 8th Feb 2016 12:45am
johnboyairey
Could it have been a slow leak, that eventually caused an overheat? If it's similar to my mothers 1.4 2005 fusion, the pump went and we had an overheat, but she wouldn't know any dash gauge from a bowl of cherries. So just steamed over and stopped. We were lucky, just a pump,and done. It was actually the bearing.
Do you have that symptom of the cylinder head filling up with rainwater, leaking in from the bonnet water jets, and rusting the plugs, causing coil pack to break down? That is a fusion and focus popular problem.
Pushrods engine... That sounds old design. Is pushrod bent?
Post #371223 8th Feb 2016 11:22am
chris595959
2015 Range Rover Autobiography 5.0 SC V8 Mariana Black
To much right foot causing valve bounce, and push rod pops out especially if the tappet setting were on the large side
Post #371265 8th Feb 2016 3:55pm
@ chris
My son drives like his grandfather on his mother's side, unlikely to be highly revved, but yes, could be the cause.
@ JBA
pushrod slightly bent, taking a risk having taps it straight with a hide hammer, know I shouldn't but its only a Ford KA Twisted Evil
I am putting the top end back together, then will take a look see at the water pump
Thanks both for your time and input, it all helps Thumbs Up .
Post #371329 8th Feb 2016 10:33pm
johnboyairey
Our pump was aftermarket, around 40 quid. It was a bit of a sod to position the gasket, with RTV sealant.. Take care.
KA stands for.........Kicks Asss!
I'm told........
Post #371347 9th Feb 2016 12:01am
The early Ka pushrod engine is based on the 1959 Ford Anglia engine....
Go go Harry Potter.....!!!!! Pete
Post #371357 9th Feb 2016 1:27am
It's a ford Ka!
I wouldn't have even bothered spending more than £10 on it and would have shoved it straight onto eBay and gone out and bought another. For £400 they aren't bad cars with a years ticket that can then almost be thrown away. True bangernomics which helps new drivers learn how basic a car can be! Keep fit Windows and no AC in some!!
Rust is on the spec sheets as well 😂😂😂 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #372112 13th Feb 2016 12:19am
This one has air con and electric windows Smile
Got it all back together this morning and started it up. Engine ran fine so sorted the pushrod problem. But after leaving for 10 minutes started to overheat again.
I believe the thermostat opened as the top hose got hot, so methinks water pump is shot. Right pig to get at though. Would like to test operation but guess that would be too much of a fiddle as well.
Oh well .
Post #372152 13th Feb 2016 1:25pm
johnboyairey
When I heard it had pushrods, I wondered if it was an old KA and if it had the old 'Kent' engine.... Maybe yours has a little zetec engine, ??? but I think you can also get problems with a stuck heater valve.... There some you tubes on fixing the heater valve, and diagnosing, and it looks easier to (bypass) repair than the water pump.
Post #372226 13th Feb 2016 11:08pm
miggit
There are only a few things that will cause it to overheat, lack of water, u/s pump or a blocked rad, from the speed you said it took to over heat, I think I'd be looking at the rad first, then the pump also check the thermostat isn't stuck shut Thumbs Up
And as far as the pushrod goes, does it have adjustable tappets, or are they hydraulic? which could have failed when the engine oil got too hot, when the engine went in to thermo-nuclear meltdown Shocked
If the tappets are hydraulic then you might want to think about an oil change too Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372261 14th Feb 2016 2:23am
miggit
Just had a thought, Ouch! Did the fan cut in before the water fall started? if not then the rad could be very blocked Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372262 14th Feb 2016 2:26am
Just to round this off:
Pushrod on No1 cylinder fell off its rocker, was slightly bent. Tapped straight with a hammer.
Had the head off, no visible signs of damage/blowing. All pistons OK.
'Stat tested in saucepan in kitchen, opened up just before boil.
New head gasket, put all back together, filled up with coolant.
Started up more or less straight away, tappets a bit noisy but rather have them on the loose side to start with.
Test drive up to temperature, no problems, no leaks, water pump working.
Installed ELM327 obd bluetooth reader, and son monitoring coolant temp with Torque lite app. Temp holding steady in the 90's.
Been OK for over a week now, and car has been on some 40 mile runs, so hopefully all solved, but still no idea why or how it dumped coolant.
Thanks to all for input and advice Thumbs Up
However, tonight son let battery go flat so Thunderbird II had to go out and rescue again with jump leads Smile .
Post #374191 25th Feb 2016 10:33pm
