![]() | Home > In Car Electronics (L322) > '04 Blank Sat Nav Screen |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 ![]() ![]() ![]() |
Hi everyone,
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Make sure the blue and white connectors on the TVs module are sound if the above doesn't work. If I remember right it's just the blue one. I got one working by easing it up and down whilst live and watching the screen.....
Thanks both for your suggestions! |
Ok I am just going to update this thread and close it.
Easiest fix was to bridge the connector. This was done by popping the cover off the TV module (the tin box is press fix) and then soldering a wire to the internal pin of the connecter for pin 1 and this was fed out through the ventilation slots. "nicedayforit" http://www.fullfatrr.com/forum/post148622.html posted the wire connections for the plug: Front of car O Red / Green O Brown O Blank O Blank O White / Grey O Brown / Red O Blank O Blank O Black O Black O Black O Black O Black O Black O Blank O Blank O Yellow / Red O Yellow / Brown Rear of car The new wire from the TV module was �T-eed in�and soldered to the power wire. Normal service resumed.... ![]() |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
Well done.. cheap fix as well... presuming you can sell the screen you bought..... Pete
