![]() | Home > Maintenance & Mods (L322) > ALTERNATOR TDV8 4.4 Removal & Refitting |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3803 ![]() ![]() ![]() |
Brilliant post.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35599 ![]() ![]() |
great write up, wiki'fied... |
Worth noting the following:
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
To tag on the end of this... We have changed a few alternator belt tensioners on the 4.4’s. Very easy to check yourselves especially with the pics above |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 900 ![]() ![]() ![]() |
I'm replacing the alternator on my 4.4 TDV8 and came across this thread but the images are no longer visible - I'm at the stage where I've removed the three alternator mounting bolts and had assumed the alternator would pull forward to allow me to undo the main + cable and plug but its not moving enough - do I need to access the rear of the alternator via the wheel well area? The workshop manual doesn't provide any indication on this. Whilst I have the fan and shroud off I've also replaced the 4x idler pulleys, the tensioner and both belts too, as I had a squeak for a few minutes after starting, so hopefully this will be resolved also. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2638 ![]() ![]() |
No mention of how to access the back of the alternator
Thanks Graeme, they're the images from the workshop manual with no instruction how you access them |
They were the only pictures posted in the thread that were of the alternator. I had saved the thread with all pictures intact.
To help any others that take on this job, once the 3x bolts securing the alternator have been removed, wiggling the alternator forward does allow access to the rear to undo & remove the + lead and remove the multiplug to then allow the alternator to be fully removed/repaced. NB the 3x bolts need torque'ing in a specific sequence when re-fitting, per the WM. |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Hi people, it looks like the links to pictures no longer work |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
HTH, look in the:
