![]() | Home > General > What first |
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 ![]() ![]() |
OK wrongly or rightly purchased a 2004 fullfat vogue ,body work and car all seem very clean.just no service history.will a dealer beable to tell me any service history from their data base espesciallly when I won't be using them for any works?
+ power steering fluid & operation
Hopefully the radio and sat nav works but just to be sure check in the rear passenger side compartment and under the spare wheel for any signs of water. Also check the condition of the upper tailgate rubber seal for condition, particularly where it goes round the top two corners. Any doubts as to condition I would recommend changing it. |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
look at the rear wheel arch where it meets the bottom of the rear doors (open the rear passenger doors and look down backwards towards the sill and wheel arch) for corrosion as that's where mine has gone and needs fixed. |
Ok car taken into stockport landrover services who inspected my new purchase.Only concerns noticed other than the faults previously noticed was.
Not quite sure how your motor is running without the MAF. when they get dirty, they affect the running quite badly. Simple part to replace.c. £85? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
I think it runs on default fuel maps without the maf, so might feel a bit flat power wise..... 2011 Range Rover Vogue SE 4.4 TDV8
Bigfella70 Member Since: 22 Jan 2016 Location: Yorkshire Posts: 106 ![]() ![]() ![]() |
Mark can you get a quote from Stockport LR for the jobs they've identified ?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Presumably if you bought a car with no history, then you got it for a good price.
The air suspension pump for example should be an easy fix, there are kits available for about £25 and YouTube instruction videos on how to sort it. (It's that easy even I managed to do it!) although you do need sometimes need a computer afterwards to reset it. |
Been quoted£400 top and bottom ball joints off sixe and near side, replacement one of those jobs that could be areal pig to do so not sure if a good price.
