Home > Technical (L322) > dim headlights
mark g
United Kingdom 2004 Range Rover Vogue Td6 Java Black
dim headlights
my headlights are ok although not great on main beam and very dim on dip, is this normal or is something not right , would changing the bulbs make any difference, thanks, mark.
Post #370609 4th Feb 2016 11:10pm
Lost for Words
Yep, probably just need new bulbs. My recommendation
Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #370678 5th Feb 2016 10:26am
Mark, have you a friendly local MOT station? If so, run by and ask them if they will check the beam pattern is set where it should be? Your MY had an issue with self levelling ECU’s and lots of them failed in the lower position or are missing from factory!... So many owners either find the headlamps have failed in the lower position or had the lights aimed/re-adjusted to point lower so they stopped getting flashed by oncoming drivers...
Remember in 2004 Xenon headlamps were a relatively new technology and irritated most oncoming road users!
Post #370687 5th Feb 2016 10:48am
i wonder if its the bulbs that are dim or the light projection on the road, if the latter then your theory sounds plausible Craig.. ... - .- -.
Post #370705 5th Feb 2016 12:04pm
Ennoch
I have to be honest that the low beam (HID) in my 2003 is woeful, and that's coming from someone used to Impreza's which are hardly the best in the business. High beam is fine but the light on dip is poor. The pattern is fine but given that the bulbs in there are of unknown provenance I suspect that it may be worthwhile putting new bulbs in. I know that in my Impreza the higher output (+120%) bulbs just don't last and after 6-9 months they usually need replaced as they've dimmed significantly. Not sure if the HID's really suffer from that same issue but it wouldn't surprise me.
Post #370967 6th Feb 2016 10:24pm
Ennoch the HID's on you car are Bi-Xenon , that means the same bulb is used for high and dipped beam and all that happens is a small shutter comes down and blanke off a small part at the top of the beam to stop dazzling oncoming traffic and the halogen high beams are really only there to fill in a bit and to give you a "flash" facility because the xenons take too long to warm up . Xenon bulbs don't fade so much as yellow a bit then fail so your problem is either alignment or less likely the shutter is coming down to far , on the whole people have nothing but praise for the headlamp set up unless the get all funny about the different colour in the various bulbs and Censored things up with LED high beams . 2008 MY Supercharged
Post #370989 7th Feb 2016 1:32am
Lost for Words
The halogen lamps still add enough light to make a considerable difference though, which is why the main beam often appears OK even when the HID bulbs are getting tired. It's a common misconception that the xenon lamps are much, much brighter because of the lumen figures but they also have a wider beam so the difference is not quite as big as people think because the colour temperature misleads. Thumbs Up Visiting from DISCO3.CO.UK
Post #371020 7th Feb 2016 10:14am
My 2003 bi-zenons are superb on dip and main, there must be something up with yours... As has been said, flap or bulb... Pete
Post #371099 7th Feb 2016 4:24pm
..........but we still dont know from the OP if its the bulb that is dim or the actual light on the road... ... - .- -.
Post #371111 7th Feb 2016 5:16pm
mark g
sorry stan i would say its definitely dim bulbs as its been on the mot light tester device and was fine, if i stand in front of the car at night, the lights certainly seem to be dim, thanks, mark.
Post #371163 7th Feb 2016 9:27pm
thanks for that Mark...gonna fit new bulbs then? ... - .- -.
Post #371176 7th Feb 2016 10:05pm
mark g
yes certainly, had a fair bit to do this week, fuel pump, boot seal, dsp, bm54, gearbox diffs and engine filters and oils, trying to get all the usual suspects done before the wife takes a shine to it , transfer box is about the only thing left,
Post #371203 8th Feb 2016 1:29am
Do you have a code reader Mark? To check for codes in the LCM or either headlamp?
Post #371204 8th Feb 2016 1:31am
mark g
yes craig got the britpart lynx, will have a look, thanks for all the help
Post #371326 8th Feb 2016 9:15pm
