Home > Maintenance & Mods (L322) > Gearbox oil
Digger7820
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
Gearbox oil
Ok here goes, please be kind I am new and I understand it's been done to death!
I have a 2002 L322 TD6 vogue auto is this oil for the gearbox any good?
MPM Premium Synthetic ATF Automatic Transmission Fluid FM+ LT71141 4L
£25.29
(£6.32/L)
Seems a lot cheaper than other oil so I suspect it's not
(http://www.ebay.co.uk/itm/MPM-Premium-Synthetic-ATF-Automatic-Transmission-Fluid-FM-LT71141-4L-/261556378181?hash=item3ce5f99a45:g:dWsAAOSwxH1T7LoD)
Many thank
Graham Range Rover vogue Td6
Land Rover Defender TD5
Grand Jeep Cherokee
Discovery 300tdi
Discovery 200tdi
Series lll short wheel base
Super 7 kit car
AC Cobra (still got)
Post #370632 5th Feb 2016 7:10am
acrr1
United Kingdom 2002 Range Rover Vogue Td6 Oslo Blue
Your car has the GM 5L40-E auto gearbox and the correct oil is Texaco Texamatic ETL-7045E which is a Dexron III spec fluid. The Texaco stuff is not always easy to find - an alternative is Ravenol ATF Dexron IIIH. Ravenol is distributed by Britpart so any independant selling Britpart bits should be able to get it. Would also be worth talking to an oil expert like Opie oils (who is a sponsor on here) for other recommendations - it's possible you might be able to use a later spec Dexron IV fluid. Although the oil you linked to says it's suitable for Land Rover it looks like it might be for a Freelander. HTH.
Post #370694 5th Feb 2016 11:25am
Digger7820
Many thanks for the information.
I am totally confused on this gearbox oil, the hand book tells me filled for life!
Read on the forum must be Mobil oil now Texaco ( I was second officer on some of there tankers).
Will any Dexron 111 or above oil do?
Again many thanks
Grand Jeep Cherokee
Discovery 300tdi
Discovery 200tdi
Super 7 kit car
Post #370734 5th Feb 2016 3:11pm
acrr1
Do a search on this forum, there's lots of helpful information about gearbox oil changes, an example is in the WIKI: http://www.fullfatrr.com/forum/topic1259.html
Re 'filled for life' there's also lots of comment but essentially the auto is just a normal gearbox with drain plugs and filters so easily changed and well worth doing. I got my (Texaco) oil from Fleet Factors in Middlesborough, around £70 for 20 litres and the genuine Land Rover filter kit from Dan at Duckworths (also a sponsor on here.) Be aware that if you do a manual flush there will still be some oil left in the torque converter. Opinions vary as to whether it's worth doing a couple of manual flushes or having a power flush. I did a manual flush on mine and changed the filter myself, easy job to do, then took it to an independant (Quattro Autocare at Ricall, York) to have a power flush using their Wynn's Magafush system.
Post #370759 5th Feb 2016 6:09pm
v8rich
England 2002 Range Rover HSE Td6 Bonatti Grey
I got my 20 litre tub from Fleet too. Helpful lot in Immingham, not too far from you Wink
http://www.fleetfactors.co.uk/lubricants-c...7045e-p387
I've made contact with Colin, (Chinkoa) to borrow his fill plug and I intend on doing it a bit like the method described here: http://www.fullfatrr.com/forum/post295156.html
Need to get the filter kit off Dan, Then I'll see about doing it first week of March I hope when my next decent off shift period is. Your welcome to come along and watch/assist if you like.
Rich
Post #370774 5th Feb 2016 7:15pm
Digger7820
Many thanks for the advice now I am seeing the light.
The spannering is not a problem, I have built two kit cars still got the cobra, it was the oil that was confusing me but it seems that the texaco one is the one to use
Once again may thanks and good motoring keep safe
Graham Bow down Bow down Range Rover vogue Td6
Grand Jeep Cherokee
Discovery 300tdi
Discovery 200tdi
Super 7 kit car
Post #370831 6th Feb 2016 9:32am
johnboyairey
Your reference to the LT71141 fluid is for the petrol model ( ZF 5hp24 gearbox)
There's plenty to read on here regarding your diesel GM box.
Post #370834 6th Feb 2016 9:46am
