Home > Technical (L322) > TD6 Injector live values
smighall
England 2005 Range Rover Vogue SE Td6 Buckingham Blue
Pleanning on doing a leak off test at the weekend, but thought i'd see what the live values were from the IIDTool. Whilst driving they all report 0 so signs are good, however on idle a number of the cylinders will report up to +655mm3. This also happens on very light throttle with little load.
As soon as there's any load or a bit of throttle added everything returns to 0. Does this sound right? Has anybody or can anybody check if there's does the same?
Post #370589 4th Feb 2016 8:47pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Had a similar question which Mikey explained very clear Thumbs Up Bow down
http://www.fullfatrr.com/forum/topic34853.html
Post #370907 6th Feb 2016 4:09pm
Discotigger
^+1 for the above thread. Thumbs Up
I think you had better check those values again as +655mm3 is a tad on the high side Shocked Shocked Shocked
Any value at tickover above +2 or +3 should be investigated, as it's probably indicative of an injector on its way out.
Normal values should be a max of +1 to +2, with a Zero or a minus value denoting a normally working injector.
All values will drop to zero under throttle.
Do you get any judder or lumpy running at tickover?
Post #370913 6th Feb 2016 5:11pm
smighall
Everything seems fine with it running, I'll test it again tomorrow and log the data to make sure i'm not being a complete muppet. That's assuming i finally get the bathroom finished which according to SWMBO is more important.
Post #370925 6th Feb 2016 5:33pm
