![]() | Home > Camping, Caravanning and Holidays > I'm off.... be good while I'm away... I'M BACK...... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8362 ![]() ![]() ![]() |
Well...
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Welcome back Pete...
Cheers, that is just an example of the type of boat we will go for, I too like the build quality of the Grand Banks but we will look at others, got a few things to sort out at home before we go back on a serious hunt.... |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
WOW! PETE.
Cheers Greg
It's a 10.4ltr V8 four stroke diesel, this spec is the lowest power output, it also has a forged steel crank, so they should last forever, 240bhp from 10.4 ltrs is just potty..!!!! It's doesn't have a turbo so no problems there.... As I said this is just an example, even another Grand Banks of the same era may have different engines, depends what the original owner specified... I also like the Defever Yachts, a lot of them have the Detroit diesel 2 stroke V8, reputedly the most reliably diesel engine ever made and it will get you home with half the engine missing..!!! (I don't plan on trying this...!!!) They also used Lugger, Yanmar, Volvo and a few others... most important thing is getting the prop size and pitch correct for the hull speed of the boat and the output of the engine to ensure good fuel consumption, if you get around 1 mpg (yes, one mile per gallon) your doing well....!!! Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
1 mpg is bad, but as it runs on red there is s saving there, and if you keep it state side it will probably turn out to be economical that your ffrr over here |
