Home > Maintenance & Mods (L322) > IID tool errors codes after heavy rain |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
From what you describe, none of the faults are real - you're getting water in somewhere which is causing something to think it has a fault.
30th Jan 2016 9:05am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
They all sound like BCM faults, so I would suspect that you've also got some water under the passenger seat I would be checking the sunroof drains are clear...... common fault over here.... Rain that is
30th Jan 2016 10:46am |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 |
thanks for the responses, i will check in the morning |
31st Jan 2016 8:24am |
