Home > Technical (L322) > Engine recon |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Wouldn't it be cheaper to just get the heads recon'd and fit new gaskets? Yesterday I couldn't spell Engineer... Today I are one!
29th Jan 2016 12:20am |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 |
Are you positive its the head gasket? Never heard of a bad head gasket on a M62 before... L322 Vogue 2003 |
29th Jan 2016 10:20pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
From what I understand about the m62 engine, you can't rebore it, as it has a coated liner and there are no oversize Pistons. You can change the bearings, but again not oversize. ( you replace crank with a new one) the heads are available secondhand. But again, the cam shaft bearings are not available oversize. The old days of picking up parts from a reconditioners, and assembling a 'new engine' are not catered for on this model. So, you should basically investigate, removing the heads, inspecting the bores for scoring, and either the bore score means find another secondhand engine, complete, or if the head is out of true, or cracked, finding another, and reassembling. You could be very lucky and just need new head gaskets. Especially if the engine still runs. £50 each I think.
29th Jan 2016 11:14pm |
