Home > Wheels & Tyres > Will 20" L405 wheels fit a L322?
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
Anyone here know if the 20" wheels (photo below) will fit a 2005 L322 Vogue ?
Post #369027 27th Jan 2016 11:19am
yes, with the correct 23mm shank nuts.. ... - .- -.
Post #369029 27th Jan 2016 11:56am
jim4244
Thanks Stan.
So I wouldn't be able to use the bolts that are currently on the car?
Where would I buy the full set of bolts if I needed them?
Jim
Post #369031 27th Jan 2016 12:02pm
jim4244
Ah! It's OK, found them on EBay.
Jim
Post #369032 27th Jan 2016 12:07pm
what wheels do you have on at the moment Jim? ... - .- -.
Post #369033 27th Jan 2016 12:15pm
jim4244
Stan, some dreadful after market things.
They are on a 55 plate FF Vogue that I am currently considering buying.
Post #369040 27th Jan 2016 1:12pm
they are indeed horrible and i can see why you want to change...btw the L405 tyres have a slightly bigger profile so the speedo will read a bit fast.. ... - .- -.
Post #369046 27th Jan 2016 2:23pm
jim4244
Stan are 19" s the correct size for a 2005 Vogue? I'm not sure what size the fitted wheels are but they look like they are possibly 21"s?
The car has a 5 speed auto box. Any idea what make this would be, as the current owner doesn't seem to know too much about Land Rovers / Range Rovers......lol
Jim
Post #369048 27th Jan 2016 2:50pm
19'' or 20'' could be OE on that year Jim... ... - .- -.
Post #369049 27th Jan 2016 2:52pm
do you have a petrol or diesel? to start with.
If you have a diesel then the box will be a G.M. 540LE auto,
if it is petrol then as it is 5 sp, you have the 4.4 bmw V8 which had the ZF5 HP24 box
see here
http://www.fullfatrr.com/forum/post105033.html#105033 Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #369068 27th Jan 2016 5:30pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I don't recommend the 20s if its a diesel to be honest - you get some vibration when stationary in D with the bigger wheels.
I changed to 19s when I got mine and a massive improvement. Ash
2016 SDV8 AB
Post #370374 3rd Feb 2016 7:14pm
good point that Ash..i had the 'vibes' on my 2005 when i changed to 20''...i got into the habit of selecting neutral at traffic stops.. ... - .- -.
Post #370392 3rd Feb 2016 8:18pm
