Home > Maintenance & Mods (L322) > L322 Towbar swap... |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
I think the tow bar will fit. It is the armature (the huge chunk of metal under the car) that changed between MY06 onwards - to do with the exhaust mountings.
25th Jan 2016 8:43pm |
davidjpowell Member Since: 11 May 2014 Location: Doncaster Posts: 104 |
mmmm Wish I'd looked under the car too now!
25th Jan 2016 9:33pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Pre 06, the exhaust hangers bolt upwards to the chassis iirc and had to undo them to get the supporting brackets of the armature on.
25th Jan 2016 10:13pm |
The car already has a non-detachable towbar (I hate them).
25th Jan 2016 10:47pm |
From looking at the fitting instructions the Armitage will not be there.
25th Jan 2016 11:17pm |
smartone Member Since: 25 Jul 2011 Location: uk Posts: 29 |
I believe all the fittings and fitting points are the same, and I've had a westfalia detachable tow bar fitted to an 11 Vogue SE and the only difference as mentioned is that two of the fixing points share the exhaust bolts so with the tow bar fitted, the exhaust hangs about 1 inch lower.
26th Jan 2016 10:55am |
Can't find anyone to do weld hangers on, so it's a new beam.
26th Jan 2016 2:33pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
it depends the type of tow bar on the car. is it a LR or Westfalia farmers type or a brink/witter type?
26th Jan 2016 4:48pm |
