![]() | Home > Technical (L322) > Noise from Gearbox - When placed in park & when engine o |
Bizarre! Sorry i cannot offer more help sir... |
DRE-750 Member Since: 08 Sep 2015 Location: Newcastle Posts: 16 ![]() ![]() ![]() |
No problem, it certainly is bizarre, hopefully it remains unserious - I'm going to take it to the local independent this weekend, so I'll keep my eye & ear on it & report back.... |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
That does sound strange. A fairly common issue with early 6HP26 transmissions relates to the fretting corrosion of the output shaft spline (where it engages into the transfer box shaft) due to insufficient or no Weicon anti-seize paste being used on assembly.
Hi Phil - that's quite a reply thanks, hopefully it's nothing mechanical, I don't know if there is a pressure which builds inside the gearbox when the engine is on and it's in drive, to then switch to Park & or Engine off which causes the pressure drop / change which leads to the 'clunk'.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
There is a thread on here somewhere from a chap who was having a similar problem on his 4.4 tdv8, I think the outcome was that it was transfer box related, but as it was under warranty it was replaced by LR so I don't think there was any further info. There is nothing that can't be fixed with a hammer😜😜
Turns out it was the transfer box |
just for info, when mine was leaking I spoke to these chaps who seemed to carry DD295s on the shelf for £800.
