![]() | Home > General (L405) > fuel |
AZIZBBU Member Since: 03 Jan 2016 Location: UXBRIDGE Posts: 30 ![]() ![]() ![]() |
Hi,
Super ,
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 ![]() ![]() ![]() |
I don't want to ignite the debate about using expensive fuels laced with magic additives but I have always used the local Tesco for forty or more years , buying their cheapest fuel for diesel and petrol and never had a problem. I think I read somewhere they are the largest fuel retailer in the UK and since I got my latest car I must be one of their best customers. I only speak from my own experience and as I don't understand Axles comments about knock sensors etc he may well be right. Geoff |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1434 ![]() ![]() ![]() |
I have had 8 supercharged and always run on Super unleaded and thats waht jlr tech suggest |
Actually to me it would seem odd to buy a car (any car) then ignore the manufacturers handbook which in my case says 95 RON, which is standard Unleaded, so its probably OK, its certainly been OK for me so far. Geoff |
95 ron might be standard in the UK but around the rest of the world it is super but regardless of that with any forced induction engine you should put in the highest octane you can get your hands on to get the best out of the engine .
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
There is no benefit (both in terms of performance or fuel efficiency) in using a higher octane fuel than the minimum required by the manufacturer.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I might be talking rubbish but I believe the debate on 98RON and 95RON is dependant on the car's ability to adjust its ignition settings to get the best out of 98 octane petrol.
You might be right …
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
I notice a difference between normal and super diesel in my SDV8, its quieter and a tiny bit keener, nothing in terms of economy though. |
You are comparing apples and pears; petrol and diesel, octane and cetane ratings, spark ignition vs compression ignition. The OP was about petrol octane rating.
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
Copied this from US website:
